Our car has a parasitic battery drain that is very noticeable.
I've found a fuse, that when pulled drops the measured battery drain from ~ 140mAmps to 10mAmps.
This is repeatable.
The fuse index says it's the heating / climatronic which I take to be the HVAC control
I know that 964 / 993 CCUs Climate Control Units have this failure mode.
Have any of you seen it in a 997.2 Carrera?
140 mAmps with fan off and HVAC off.
I'm uncertain how to troubleshoot the CCU
Thank you
Since I'm making this troubleshooting process up as I go along, I just;
Took the meter out of the circuit.
Connected the battery
Key on
Cycled thru all of the HVAC functions
Turned HVAC system OFF
Put the meter back in the circuit
No change
sad face
