Good Morning,
How do I remove the Driver & passenger side Vents? I know there are 3 screws holding it in. 2 on the side & I is hidden behind the round light selector on drivers side? thank you.
passenger side has 3 screws you mentioned. after taking out the screw, pull the vent out.
driver side requires you to pop/pull out the headlight switch.
Are you replacing stock ones with CF or something?
Driver side;
0. After removing 3 screws,
1, pull out the black round trim (which has labels on it)
2. Remove the nut at the center
3. Disconnect wire connector below
4. Free the switch module from the plastic housing by turning counter clockwise.
Thats it.
I have Porsche OEM Silver a/c vents, if interested, email me. (jinijazz@yahoo.com)
Willing to accept black soft feel vents as trade in :)
