Hi All,
I fitted a new Sport Design steering wheel this weekend. I previously had multifunction with heating. I swapped out my old 2-stalk unit for a new 4-stalk that also had cruise control and OBC stalk to control the instrument cluster computer. My existing clock spring was moved over to new stalk assembly.
I used PIWIS to edit the build sheet for the correct steering wheel & cruise control options. I then coded to all modules. The steering wheel works great, even pressing both paddles goes to neutral.
Problem I have now is that the OBC stalk for controlling the cluster is not working and neither is the cruise control. The OBC stalk is slightly more important than the cruise for the time being though.
I have searched for ages in PIWIS to see the stalk is an option I can select, but can't see anything. I have also taken it all apart again thinking something has come loose but it all looks fine.
Totally lost now. Any ideas would be appreciated.
