Started with P1128 code every 1000 miles serveral times, then both P1128 and P1130 600 miles later, now 100 miles after reset. Anyone know the proper way to clean the MAF; I'd like to try this before replacing.
I used rubbing alcohol in a plastic cup. Swished it around a few times and let it air dry. Cleaning did not clear the exact same codes you have. Talked to a few listers here and on PCA tech and they said it's the air-oil separter. Check the archives for pictures and some details on replacement.
Keoni986
