Yes, the big one going from thermostat to pipe to front radiators.  I disconnected the snap in place end during water pump, thermostat and coolant reservoir replacement and ended up with a massive leak at he snap in place end.  Ordered new hose, lightly lubed the o-ring, reassembled and still have a small leak.  Is there some trick to these hose ends?
You shouldn't need lube on the connector end but it shouldn't hurt either.  If it's still leaking, I'd check for fitment issues (OEM vs. AM) or debris interference. It's pretty straight forward so it might just be something obvious. Good luck!
OK, found it.  I failed to correctly position the hose clamp on the hose coming off the top of the reservoir.  All is well in Paradise again.
