Hi all,
I have heard reports of oiled type air filters causing contamination of the MAF, I know that once upon a time MAF sensors went through a heating cycle to "burn off" any contamination. I have no idea if they still do this?
If this was the case then you could easily end up with a burnt on film from an oiled filter.
Now here's where I'm guessing.... If you have a significant oil leak in the engine bay, RMS or such like, drips onto the exhaust (common from valve covers) this contaminated air would be drawn into the engine and could affect the MAF in the same way as an oiled filter.
So to my question..How many of you have suffered a MAF faliure soon after an oil leak?
I certainly did, mu RMS was pretty bad, I regularly had oil spots all over my rear bumper!
John
