Pretty much the same as the Carrera - except they are bigger.
It appears that if there are vibration dampers then they come with the pads.
Front/Rear Brakes
Thanks, that will do it, I will write a how-to with pix when done.
Front/Rear Brakes
Before you do this, make sure you have a serious wrench to loosen and tighten the caliper bolts. The tightening specs for the bolt (number 8 in the picture on the left) is 240 ft-lbs. Make sure to replace the caliper bolts and caliper hardware.
  • 3 years later...
Loren,
What type of screw holds the rotor on? Phillips? Should I use an impact driver to take it out?
Just one single Torkx, don't forget to adjust the emergency brake shoes on the minimum setting before removing the rear rotors, and readjust with the new ones till proper specs.
Thanks RFM
