I have just finished up replacing my front passenger side window regulator as the cable in my original one snapped and thankfully after the window was already fully up. I replaced the regulator with  a brand named Magneti Marelli AC1642 from fcpeuro which was listed as OEM brand. The window works but it now only rolls down 2/3 of the way and then stops. Is there a reprogramming of the window that needs to be done or could there be something wrong with the regulator that I installed or something else I need to do to adjust it.
