Hi, Need the torque specs for 08 boxster rear drop link and stabilizer.  Stabilizer to frame 48 Ft Lbs
        Drop Link to Shock 63 Ft Lbs
        Drop End Link         ?(I found 34/48 and 56)
Thanks V
Stabilizer to frame is correct, as is drop link to strut; drop link end is more complicated: 37 ft. lbs., then loosen 90 degrees, then final torque to 48 ft. lbs.
