Hi Fellow Porsche Nut Jobs,
LOOKING FOR ADVICE ON LISTING PRICE FOR MY CAR. I'm considering selling my 2002 996.2 Cabrio Tiptronic and replacing it with another 996 (this time a 6 speed manual):
- 161K miles on chassis
- 59K miles on fully documented engine rebuild with IMS Upgrade. The IMS upgrade was listed as a "Pro Engineering IMS" which I can only surmise as the mechanic being lazy and shortening "LN Engineering Pro IMS". The rebuild was extremely thorough with very detailed descriptions of the rebuild.
- Bilstein B6 dampers installed by my trusted Porsche SoCal race shop in 2021. Mechanic confirms everything else on suspension is nice and tight.
- New Textar brake pads installed 2021.
- Full alignment with corner balancing performed in 2021 by same guy who aligns every single Singer Porsche.
- New engine mounts, secondary air pump, headlight completely rewired in 2021
- Has Kenwood Car Play (bluetooth, ready for camera, Pandora, etc)
- Aftermarket LED fog lights.
- 2 keys
- "New-ish" Continental Sport Contact Extreme tires all around (Front = 225/40 x18 dated 2019, Rears = 295/35 x18 dated 2020).273751485_4934465426644532_8982065203374082234_n.jpg.643cf77bf02c046e7a6bc78aa95192b6.jpg
- Every single button, dial, function on the car works as it should from the factory.
CONS:
- Has a "sweaty" RMS (term used by the Porsche tech). It leaks about 1/2 teaspoon of oil per week.
- The right fender has a small spot where the clear coat has spiderwebbed on the surface.
- No record of service on Tiptronic.
- Has typical creaks and minor rattles typical of a 20 yr old car, especially a cabriolet. But mostly interior plastic against plastic.
- Original seats have tears, but will include a nearly brand new set of 996.1 power seats.
- Has a small spot on hood/bonnet about 1cm diameter. Covered up by the stripe so can't see it, but it's there.
With that said, I'm looking for honest, fair, and unbiased recommendations on what I should list this car at.
Edited by RealRide Racing
