Hi,I have some results from a compression test :   4 263     1 260
        5 269     2 265
        6 270     3 260
From what I've read these numbers seem high...but they are less than 10% apart. Thanks V
Edited by vza
They are a touch high, but not by that much.  It could be a testing system accuracy issue, but meanwhile be happy they are high...........
  • Like 1
Porsche uses a leak down value rather than compression testing, but any Boxster worth its salt would have compression test values north of 200-210 PSIG (throttle blade locked open during the test).
