Hi
Have searched and found plenty of info on this forum about the Oxygen Sensors and as a first step it  was suggested to remove and clean, are we just talking about an electrical plug connection or can you clean the actual sensors? if so recommendations on what to use please.
I would try clearing the code and see if it comes back first.  You never clean the sensor itself, quickest way to kill them.  Your code is an "aging" code, which means the sensor is probably on its way out and needs replacement.  As they are not that expensive, and you would need to remove the old sensor just to try and "clean" it, just replace it.
