Hi
Is there a security code for the CDR23 with Bose in a 2004 986 or is it just coded to the car? want to disconnect the battery so checking first if i will need a code?
Also the Sound button doesn't work so can't change the tone/balance etc, any resets or tricks for this please?
From the Lost Radio Code FAQ...
"CDR-23 (or later):
These radios are security tested on the MOST (fiber optic bus) system to see if they are the "programmed" radio. The radios are programmed and recognized by the car’s DME and can only be replaced by a shop with a PST2 or PIWIS. These radios will not request a code when battery power is disconnected."
  • Thanks 1
