The radio in my 996 suddenly stopped working. The display flickered, went off and when turned back on asked for the radio code.
When I entered the radio code it was not accepted (entered three times and it went to the WAIT screen). I have tried since and the same thing happens.
I know the radio code is correct because a) I have the original card with the serial number and code on it, and the serial number on the card matches the serial number on the radio; and b) I have previously used this code on the same radio and it was accepted.
Does this suggest that the radio has just died completely or is there something I could try to see if I can get it to accept the code?
Why don't you use the procedure in the Lost Radio Code FAQ to get your radio serial number (displayed - not the one on the label).
Get me that serial number Iand I will look it up and see what it says the code is.
If it is the same then you will likely need to repair or replace the radio.
If it is different the you can try the new code....
  • 4 weeks later...
