2003 Carrera Coupe, 6 speed without PSM;
Pelican only lists front sensors.  I am 99% sure all four sensors (front and rear) are the same.  My left rear is cracked.  Am I correct in my assumption?
All four wheels use the same sensor: 996-606-406-00, about $143 each at retail.  And be cautious about buying "factory" items from Pelican, they are known to substitute non factory parts as "OEM".
Turns out the previous owner tried to jury-rig a fix for the broken sensor connector for the ABS speed sensor and Brake wear sensor connector.  I need the replacement wire harness for the left rear without PSM.  Pelican shows front only or harnesses for cars with PSM.  Since I plan on only using the connector and 12 inches or so of the replacement harness to splice into the existing wiring can I assume any of the available harnesses meet my needs?
