Anyone know where the plug is for the rear brake sensors? The tech removed mine to install RS 29 pads and I was going to install jumpers to shut off the warning light.
Have the tech give you back those sensors and plug them back in...then fold the sensor over and zip tie the whole lot. The plugs is located right on the rear suspension hub assembly.
