Is it necessary to locktite the flywheel bolts and clutch bolts? My original flywheel bolts are all blue, while my replacement bolts which are OEM,  have no visible coating. Also my replacement OEM clutch bolts are silver. The clutch bolts that I removed are gold color with no signs of locktite.
Because the flywheel bolts are torque to yield, and are acutally stretched under load, thread locker is not required.  The pressure plate bolts on the other hand are relatively low torque spec bolts, so they would benefit from an application of a medium strength thread locker like LocTite blue.
In no case should either the flywheel or pressure plate bolts be reused, they must be replaced.
