Hello. Is :drive: there an RPM limiter on the 2000 S? If so at what RPM is it supposed to kick in? I found myself the other day @ 7500 RPM. I thought it was only supposed to go to 6800?? Is this Normal? This is my first porsche...Thank you all for your help
I believe the rev limiter for a 2000 is 7100 rpm, check the manual. Assuming the rev limiter is working correctly as you reach the limit the gas will cut off. It is possible to exceed the limit if you mistakenly downshift to a lower gear at too high a speed.
