2003 Carrera coupe, 54K miles:  I am working on finding what is considered normal for these cars.  In this instance the oil pressure fluctuates slightly when warm at idle.  Once underway it is relativly steady.  Pressure readings are fine for the load and rpm when underway.
Edited by evoroadster
Several years ago, Porsche released a warm idle low oil pressure update for the M96/97 engine oil pump that consists of an upgraded spring and piston to address this type of issue. Cheap and easy to install (Piston: 997.107.125.01 ($ 5.00)
Spring: 996.107.127.53 ($10.00)
Gasket: 996.107.123.50 ($ 2.00)
  • Like 1
