Hello,
I have a 98 Boxster 2.5 with 150k miles and i'm struggling to solve a problem.
The car runs good when it's cold but once it warms up, idle goes down (500-600rpm) and stalls.
I already replaced air filter, fuel filter, spark plugs, ignition coils, AOS, MAF, O2 sensors (Bosch universal), IACV, variocam pads, 3 chain tensioners,
I also cleaned throttle body.
The problem persists, the codes are p0301-6.
I'm running out of ideas, and money...
Thanks in advance.
Edited by Garage Sales
35 minutes ago, Garage Sales said:
Hello,
Thanks in advance.
One of the primary cold vs. warm differences on these engines is the air/fuel ration.  When it first starts, the mixture is richened (open loop) to help it run well, and it then leans out (closed loop) when it warms up.  If you had a small vacuum leak in the intake system, the cold enrichment of the mixture could be enough to let the car run smoothly; but when it goes closed loop, the mixture is too lean, causing random misfires.  You can determine this by monitoring the cold air/fuel ratio vs the warm ratio; and if it is a vacuum leak, find it by smoke testing the system.
Good luck; this type of problem requires time, intuition, and focused diagnostics.
Thanks for your reply. The problem is only when warm but on idle. I can start the car, drive 100 miles and when I stop at a traffic light, idle goes down, stalls and smells unburned gasoline.
Smoke test showed no vacuum leaks.
