2003 Carrera; do the post CAT O2 sensors only monitor CAT efficiency or do they also feedback to the ECU for fueling adjustment?
The post cat sensors do both 1) monitoring the cat efficienty and 2) taking care of the mixture fine tuning by correcting the values after the cat, too rich or too lean via the control box, they are also oxygen sensors. the best result is obtained with only a small change from time to time compared to the pre cat sensors especially at full acceleration. This is also a  quick check that the sensor is working and therefore not blocked.
