The windsheeld washer pump dosent work, but the head
light washer pump works fine.Tried first to change the pump, but still no pumping. Then I changed the stalk/windows wiper arm.
Nothing happend, still no pumping from the washer pump. All other functions on the wiper arm works fine. This tells me there must be an eletrical fault between the wiper arm and the  pump wire connection (two wires goes to the pump top).
Cant find any fuse for the windshield water pump, but there is one for the headlight washer pump. Anyone had this problem?
Thanks, Per Gunnar     knabbernozzi@gmail.com
vindusvisker bryter 997.pdf
