Ok so i replaced the climate control unit that died on me last fall...the good news...the new unit works...couple of questions...when i first hooked the battery back up and put key in and turned to the first position the CC headunit display blinked...once i hit a button or turned the key further it stopped blinking...also while the CC headunit seemed to work, the fan wasn't coming on...after coming in and checking how to switch from C to F display i went back out and the fan will blow the doors off...weird...could it just be the computer getting recalibrated?...any ideas...as always, thanks.
Edited by brekas
Anytime a new AC control unit is replaced you must perform a system test with the PST2 tester in which the "blinking" of the display will stop.
thanks...i was hoping it was something simple like that...i'll have my dealer do it when i take it in for hibernation this winter.
