You are likely going to need a Porsche scan tool to diagnose what is going in the front end control unit. Sometimes a re-programming is all that is needed - provided there are no faults reported.
19 hours ago, Loren said:
No faults? No broken wires from the cruise control?
If so, then you will likely need a new (or used) front end control unit.
The brake lights are always on as well when I turn on the car
1 hour ago, Loren said:
Sorry, I missed your post before. It is under the instrument panel on the drivers side.
Will this fix the issue for the brake lights as well
2 minutes ago, Loren said:
I doubt it - that may be a separate issue.
Well The cruise I put it on I see the light but does not engage and when I turn on the car the brakes lights are always on without me present on the brakesThe cruise I put it on I see the light but does not engage and when I turn on the car the brakes lights are always on without me present on the brakes
Lots of possibilities - brake booster, shorted wire, bad bulb connector, bad switch, control unit.
Did you drive through high water at any time?
