I am planning on buying some sort of software for my laptop that will allow me to read codes and some even promise to reset alarms and such. Tuning curves? Graphics?
What are you guys using and what is recommended to stay away from?
Any help is appreciated.... general consensus would be awesome!
Much appreciated!! :cheers:
I have the Durametric software and adapter cable and it works great. It not only does the engine codes but will also do the Temp Control System, ABS, Airbag, Seats and Tip diagnostics and code resets. You can usually find it new on Ebay for less than $200.00 or direct from Durametric at http://www.durametric.com/ for around $300.00. It is worth every penny.
