Hello, I need help with my 1999 Carrera 4 with 70K miles. It was running fine last week.
I then decided to change motor oil and replace spark plugs. It was on a two post lift for a couple of days (though it shouldn't make a difference).
Here are some observations:
- engine cranks but does not start. No firing at all.
- there is a high pitch noise when key is turned on. It seem to come from engine bay. (hopefully, it is the sound of fuel pump.) I also wondered if I should be smelling gas which there is none.
- Durametric showed fault code under engine (something like secondary air system fault Porsche fault code 90 or something. It fault codes for both banks.) After erasing the code, they did not come back. However, the engine still doesn't start.
- is there a fuse for ignition or fuel system?
Please help me with this!!!
