1999 C2 Cab 6MT 75K miles
I have a small oil leak at the right rear of the engine.  Just a drop or two on the garage floor.  I thought it was the cam solenoid seal so I replaced it.  And it is still leaking.
Once I removed the air box (also did the resonator removal and red cap-off trick)  I could see the leak on top.  The crankcase vent elbow is covered in oil/dirt.  But I've seen some threads about a cam position sensor o-ring that could also be the source of the leak.
My question - Is there a way or a trick to tell which one is leaking?
I might just replace them both to be sure.
GENUINE PORSCHE CRANKCASE VENT ELBOW
R99610704751
