I recently changed the engine oil and I have now an oil leak from the oil filter cover cap that is quite noticeable with the engine running.
Everything looked normal during the re-installation of the oil filter cover cap after changing the oil and initially there was no leak.  I torqued the cover cap to 19 ft lbs  as I normally do and when I re-checked the torque after noticing the leak this morning, the cap moved just a little bit.
What could be the reason of the leak?
I intend to install a new ring on the oil filter cover cap.  I assume that it is not necessary to drain the oil completely to do this.  How much oil should I plan to put in the engine?  Now the oil level is at 80% of the distance between the min. level dot and max. level dot on the dipstick.
The filter housing hold less than one liter of oil; if you are careful, you will lose very little replacing the O-ring.  Also, make sure you didn't leave an O-ring behind when you first changed the oil (common mistake).   As for the oil level, you should be running it two bars down from full in the first place.
JFP, many thanks for all the information provided.
