Hi All, 2008 Boxster Base, Can't get the key out of the ignition. Read that the batt.has to be fully charged, don't know how true that is. Going to try the paper clip in the window today. Maybe needs new electrical part of the ignition switch? Thanks V
Have you tried to turn your steering wheel while trying to get your key out of the ignition ? this sometimes happens to my 986 when the steering wheel locks.
Cheers,
Michael
If your steering wheel is not mechanically locked (i.e. you can move it freely) then it might be an electrical issue, apparently tiptronic cars don't release the key unless P or N is engaged which would require a good battery to read the proper signals.
Maybe the link below could help.
986FORUM.COM
986 Forum - for Porsche Boxster & Cayman Owners
Its a manuel trans. I got it out w/paper clip. Gets stuck again after start up. I suspect its batt.or ignition switch. Will try batt. 1st.
