Is there any way of doing a hand over reset on my 2006 Porsche Carrera 4s convertible with my purschased Durametric software?
if yes; please help;  if no;  is there another way to get it done aside from dealer intervention.
my Homelink and heated seats no longer function after battery replacement.
Welcome to RennTech :welcomeani:
You cannot do that on your model with the Durametric system, you need access to a PIWIS unit (factory diagnostic system).
I’m from Montreal;  does anyone know someone in the area that can do this aside from the dealer?
Is this common?   A battery replacement should NOT require a trip to the dealer or mechanic - for any car.
I agree but this is what I’m reading on all the forums… do you guys think it may just be the fuse?  If so; do any of you know which one it could be.
This phenomenon is not unknown; when the battery goes weak, communications with one or more modules can be lost.  When that happens, the module needs to be reinitialize, which requires the correct diagnostic system.
I doubt you will find anyone outside of the dealer with a PIWIS.  While I have seen a few that have it, it's too cost prohibitive for most independent shops (something like ~$10K/month).  When you need access to a PIWIS you usually just need to bite the bullet and go to the dealer.
