Car is 996 C4. Exhaust is popping when declerate. Mechanic found an exhaust leak but fixed it already. Exhaust still have a little bit of popping. I've found some articles on the web which said that popping on deceleration could be caused by a faulty "air injection diverter valve" :D . Does 996 have one? Any views?
The air diverter valva eon the 996 is for the secondary air pump and should not cause a problem because there is a check valve inline. Get out a vacuum gauge and hook it up to one of the vacuum lines and see what your reading is on a warm engine at idle. Might aid in determining an air leak.
What year car is it?
Edited by 1999Porsche911
