No need to apologize, it takes years of working on these engines before you become proficient in "Porsche speak"............🙃
So I was looking at my camshaft and cylinder head and it appears to have some pretty bad scoring on them.
attached pictures
is there a way to clean these up? Or am I just putting them back in as is? Unfortunately?!?
Edited by Johnny-5
Not really.  As there are no removable bearing inserts in the cylinder hear or cam cover, they simply cannot be bored or honed to clean them up as that would make the assembled cam bores too large; same with the cams themselves.
Expand
I was going to use some fine sand paper but had a feeling that would be bad. So wanted to post it on here. I had a feeling that was the case. If I was to put in another set of cams it would probably mess those cams up. I guess i got no choice but to put these back in as is.
How long do you think this motor will last with that scoring? How does that happen? To long of an oil change interval?
Expand
Without physically seeing the entire engine, the answer to your first question would be a total guess.  As to your second question; using crap oil, running the oil too long between changes.  You should be running a high ZDDP content oil, changing it (and the filter) every 5-7K miles.
You could consider using a high quality oil like Driven DT40 with 5K mile OCIs.  You can buy it at advance auto parts using coupons for the 10 packs (not single quarts), when it's available.  It comes and goes, I stock up and check every few months if I need more.
Like JFP is saying, one problem with running cheap oils even at short OCIs is they shear at high temperatures turning the oil into something closer to water than a lubricant.
Edited by Silver_TT
Thanks for the responses I figured that was the case with the oil! This is a replacement used I picked about a month ago so don’t know the history on it. I ended up getting some bottle of liquid moly so will use that for now. I’ll pick up some driven on the next round.
Regarding the variocam pads both sides are done and have been properly timed. Wasn’t as hard as I made it to be. Bank 1 is sealed just need to seal up Bank 2.
Did have a question does Bank 2 have this small heat shield like Bank 1? I didn’t see it and saw there is a small screw hole for something was just curious if it was missing it.
WWW.PELICANPARTS.COM
Genuine Porsche Cylinder Head Heat Shield $4.00. Call (310)626-8765. May Qualify For FREE SHIPPING. Parts# 996 104 233 01 996-104-233-01...
Attached a picture of the screw hole in question.
I'm not really sure on the usage of that small part.  You may want to check with a dealer parts department to determine if your year engine used two or only one.  The PET only lists one being used.
Expand
Ive looked everywhere and couldn't find anything that would go there online. Ill call the dealer tomorrow and see if they can shed some light on it for me. Just weird for it to have something like that and not have anything go there? But as you stated I only saw one and that was on bank 1. Thanks JFP!
