Greets,
My 2004 CTT has developed an occasional noise/behavior related to the drive-train. It often occurs in stop and go traffic, after accelerating from a stopped position and becomes evident in the 20-35mph range. The sound starts with a low roar and will continue until I lightly tap the breaks as which there is a pronounced thunk sound. After the thunk, the roaring stops. This issues has existed before and after the Differential, Transfer Case, and Transmission fluids were changed.
To aid with the diagnosis, I put a recording device under the front passenger floor mat and drove around until I could reproduce the issue. The attached audio file has both the roar (beginning at 17 seconds) and the "Thunk", which happens around 33 seconds.)
Anyone have any insight into what could be causing this behavior?
roar then clunk 2004 955TT.mp3Fetching info...
Did you check the drive shaft bearing? When the rubber mount lets go it makes a thunk sound as the power comes on and off and can make a roar noise when the bearing itself is failing.
