first time in 7 years and i finally got a waring light on the dash. ABS failure. I was headed down my driveway, and at the bottom I have to go out at an angle and often times 1 wheel will come off the ground. at the same time i pulled the emergency brake as i did an oil change this am and wanted to have a quick look underneath before heading out. was it a combo of this that triggered it? i have a simple scanner but it shows no codes. what is the best approach to troubleshooting this.  also, my car does not have PASM.  not sure if that matters with diagnosis.  thx in advance.
