Just how the heck do you disconnect this. I opened the little flap and tried to press the clip together to disconnect it with no success. What's the trick? '05 MY.
The connector has two tabs that lock it into place...you have to press both tabs at the same time and then pull, you need to press the tabs really hard for it to unlock.
You can twist the whole connector assembly and unlock it from the roll bar to gain better access of the tabs if neccesary.
on the '05's the harness does not attach to the rollbar (did on my '02 MY). But the harness run down the same area behind the passenger seat. The harness is too short to move the rear speaker unit around to get a good hold (or view) of the connector.
