A few weeks ago I saw a lot of fluid on the ground under my Boxster, I jacked it up and found that it was coming out of the differential.  I thought the seal was bad but actually the short inside axle had pull out about 2 inches.
Can anyone tell me why the pulled out?  As far as I can see there is not bolt or anything that holds it in.  I removed it entirely and compared what I saw to a picture on Pelican and there is gaps between each of the bearings and the green plastic (spacer I guess).
I reinstalled it with a new seal but I am concerned that I didn't fix the issue with why it came out so it will probably happen again.  Any help would be appreciated.
Roy
