Hi,  I have a 2008 cayenne s with 105k miles.  Started getting p0455 code frequently.  Replaced gas cap, purge valve, diagnostic pump and carbon canister.  Everything is new Porsche part.  Well I smoke tested the system today.  Started with the t connector on vacuum pump-nothing.  Disconnected purge valve and smoked back to carbon canister.  The filter on the carbon canister is smoking.
Question:  can this be the source of the large leak p0455 code?
Thanks, Chuck in Missouri.
  • 4 years later...
The mystery has been solved.  It was the valve cover.  Porsche of Omaha wanted 7700 bucks to replace the injectors and valve covers.
