I am in the process or replacing the passenger side window regulator.  I assume that the OEM window regulator that I have just purchased is ready to use and does not need any additional grease.  But does the old motor that I am re-using need any grease and if so, what type of grease should I use and where exactly should the grease be applied?
For the most part, the regulators are lubed with white lithium grease, and a very little goes a long way with this stuff as it tends to stick to everything, so you don't want excess getting all over everything.  The motor should not need relubrication.
  • Like 1
