Hello all !
Here in Canada/Quebec prices are very high and sale taxes at 15%, so everyting is expensive.
I'm looking for an exhaust system to replace the stock exhaust (not PSE) on my 2014 Boxster S.
Here are the options :
1 - The most expensive, Porsche PSE installed at the dealership including button in console and programming = $6,800
2 - The middle one.  Porsche PSE with and aftermarket valve controler = $3,500 plus $500 to install it.
3 - The cheaper.  I have the option to buy a used but never installed Fabspeed Valvetronic Exhaust for about $2,200 plus $500 to install it.
So I'm wondering how this exhaust (Fabspeed Valvetronic) performs compared to stock exhaust.
When valves are close, is it very louder than stock one ?
Any drone when valves are closed ?
Thanks.
Edited by Parrnan
On 2/15/2021 at 11:53 AM, Parrnan said:
Hello all !
Thanks.
The Valvetronic System, when closed, will sound very similar to stock. When the valves are open it will dramatically increase the tone of your Boxster. Our valved systems utilize Helical Vales, Same as what's used in the OEM Porsche, Ferrari, Lamborghini systems. In terms of sound and performance, you cannot do any better than that system!
Fabspeed will even transfer the Lifetime Warranty to your name!
  • Like 1
Thanks.
Fabspeed John, the valvetronic system for sale is the first genetation product, the one without the upper pipe (seems to be in pretty good shape).  Is it a big issue ?  What are the advantages of the second generation of the product over to first generation ?
Fabspeed John, I really need you advise on this.  Is a first gen product worth it or should I wait ?  I can get it for abour $2200 CDN (it would be $1750 USD to compare).  How this system hold in place, I do not see any mounting brackets ?  Thanks.
Edited by Parrnan
Parran,
I am happy to help, Would you please Email me? john@fabspeed.com
If you are buying the system used, i cannot give you any insight on what the previous owner is including in the sale. If you buy it first hand from us I can guarantee all needed hardware is included and will be covered under our Lifetime warranty.
We changed the design because customers reported droning in the 2-3k RPM band. The new Gen. is drone free and sounds incredible. Much more worth it in my opinion.
Edited by Fabspeed John
  • Like 1
On 2/23/2021 at 12:24 PM, Fabspeed John said:
Parran,
Hello John.
I have a question.
If I deceide to make an offer on the used Fabspeed Valvetronic system (generation 1), is the retrofit of the anti-drone tubes is something that can be performed ?  If so, would it be very costy ?  This system is on the best sounding on the market, but I cannot take the chance to buy it knowing it will drone a lot between 2000-3000 RPM on higher gear.  But if the anti-drone tubes can be retrofitted that might change the situation, depending on how costly it would be of course.
Thanks John.
