Hello
I'm new here and I hope someone can help me.  My Cayenne fails to pump when it has a quarter of a deposit.  The pumps are new as well as the filter, when I start the engine with a quarter of a deposit the pump shows signs of power for a short time but the engine starts well but then goes down.  I've done several tests without results, but when I remove the relay from the right pump it continues to work when I take the one from the left the engine stops.  I put the right and left relay again, the right pump has power and the motor does not turn off, if I turn off the motor it returns to the same.  Does anyone have any idea what it might be?  I appreciate the help you can give me.
