My 2004 Porsche cayenne s oem radio went bad. So i changed with a oem radio from junkyard how do i get the radio code for this . Serial # on the used oem radio is
35025936
Edited by Tony Nguyen
Put in wrong serial number
From the Lost Radio Code FAQ...
"CDR-23 (or later):
These radios are security tested on the MOST (fiber optic bus) system to see if they are the "programmed" radio. The radios are programmed and recognized by the car’s DME and can only be replaced by a shop with a PST2 or PIWIS. These radios will not request a code when battery power is disconnected."
This topic is closed.
This topic is now closed to further replies.
