2000 Boxster S - My passenger side running light and side light are not working.  I switched bulbs and bulb holder socket from right to left.  Everything works on the left, nothing on the right.  The fuse was switched between A3 and A4.  Works on the left, but not on the right.  Any suggestions?   Any ideas where they connect and where they go?  Electrical is not my forte.  Thanks for your help.
Thanks.  I would check that.  If I don't have a ground, would you suggest replacing it or trying to trace it?  Any idea how to find out where it grounds?
Just follow the brown wires. I would start by checking the ground terminal inside the light and see if it has continuity to ground using a multimeter.
