All, I ran a Durametric Output test on my 2005 Turbo but the software does not tell you which actuator it is activating.  Does anyone have a list of the actuators (relays, motors, etc) in the sequence of the test?
So I have been fixing things and re-running the test.  This is what I know so far:
START
n75 tank vent valve(front left intake clicking)
(no sound on my car)?
right secondary air pump (motor running)
Boost Pressure Control Solenoid (front right intake)
Behind fuel door (solenoid clicking)
Ambient Air Solenoid (back left intake)
Vacuum Pump (right firewall motor running)
fuel pump? - air compressor? (back under motor running)
Left Secondary pump (motor running)
Fuel pump? (back under car motor running)
Left cooling fan running
Right cooling fan running
Aux Cooling Pump (in left front fender motor running quietly)
DONE
Edited by davesly
