On my 1998 986, I had a mechanic adjust the travel of the brake pedal - if I recall correctly, there is a shaft that is accessible underneath the brake reservoir. I absolutely loved the change - you had to push the brake pedal very little to get pad engagement.
My new to me 981 has pretty long travel with the stock pads. Is this still something that can be adjusted?
They are two different cars - I guess my question is, is that rod still adjustable on the 981?
This is what it looks like on a 986:
Edited by steve_wilwerding
