2011 Carrera 911 GTS 16000 mls. Check engine light is on, idle is slightly high at around 1200. Durmetric indicates this Fault Code 997.641.981.35. Does anyone know the definition of this code?
Hmm... Not sure Durametric is right...
997.641.981.35 is the part number for your instrument cluster - which can not cause a CEL or high idle.
Perhaps make sure you have the latest software and try again.
Thank You. Actual code P0001&P0008  All cleared now, so will take a short drive to see if any codes reappear.
