I recently replaced the driver side door latch/lever on my 987-1 and now the memory buttons will not operate the door and outside mirror settings. I suspect I did not reconnect the memory button wiring correctly when re-attaching the door panel. Is it possible to pry the button assembly loose from the door panel to check the wiring without removing the entire door panel? Or, must I remove the entire panel to check the button assembly from the back side? The panel fasteners were not very cooperative when I last re-attached the panel, and I am not sure they will survive another removal/replacement.
Best,
Bob
