  • 11 months later...
Did you ever get this figured out - I know it's been a year, but I like responses...
Near the rear lights under the vehicle above the bumper mounts is a ground.  Remove the nut, use a wire brush on the body bolt and wire connector and torque down the nut again.  This can cause some instances of lights not going out.  Typically you see this after a re-paint where the threads are covered in paint and not providing a good ground.
Front light grounds are inside the frunk on my older cars, assuming the same on the G body.  Report back what you find!
  • 4 months later...
