Part number for two small hoses under Tiptronic transfer case.
Hey all,
Looking for the part numbers for the two small rubber hoses that connect to two tubes that run directly under the transfer case on 997.1 Turbo Tiptronic. I'm attaching a photo the two hoses I need are the ones shown inside the red box.
Thanks in advance.
(I don't remember where I got this photo. I'll give credit if I can figure it out.)
Edited by gophaster
Hi Loren,
I was able to crawl back under the car and get the part numbers directly from the hoses. These two small hoses sit right below the Tiptronic transfer case and it seems that if you get the somewhat common leak on the Tiptronic transfer case gaskets the hot ATF oil drips right on top of them and the heat seems to deform them a bit over time.
They are shown in the diagram below as Number 41  and Number 42. Part numbers 99610621275 and 99610622275
