I removed my passenger seat to have it reupholstered.   Shortly after I noticed an airbag warning light.  When reinstalling the seat the light remained on.   I took my diagnostic meter and checked the fault.  It said seat buckle issue.  I cleared the fault but the light remains on.  The seat belt works fine as well as the power seat back and heater.  Tried to clear 2 more times but no luck.  Any ideas?
There is a bulletin from Porsche about relocating the ground for the drivers airbag/ seatbelt buckle circuit because of this fault. Search for that.
How are you clearing it? (what tool?)
Has the grounding TSB been done on this car?
Also, the original seat belt buckles were replaced with a newer style (gold plated contacts).
