Hi all, Ugh....I was putting gas in my 99 boxster  from a 3 Gall can. I used a plastic turkey baster to extend the funnel I was using. Apparently the baster was not gas proof and began to break down and a piece broke and I believe fell into the tank. It was a piece of plastic the size of a pea. I assume it will dissolve and nothing will happen. The tank is half full. Any suggestions. Thanks v
